I am planning to build a pc with a 7700k and 2 gtx 1070 but there is one problem that 7700k doesn't come with a stock heat sink and i can't find a stock heat sink for LGA1151 but I did found one stock cooler for LGA1155 on Amazon IN. What should I do, should I just use the liquid cooler or use the LGA1155  cooler for the test build
https://linustechtips.com/topic/751317-test-build-problem/
Why in the world would you buy a 7700k and 2 GTX 1070's and still use a stock cooler? Get something like a Corsair H110i.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/751317-test-build-problem/#findComment-9508247
man i want to do a test build that is done outside the case to check if everything is working for the build i am using a corsair h100i
https://linustechtips.com/topic/751317-test-build-problem/#findComment-9531302
