13 minutes ago, GermanPCBuilder said:
Quick question I want a free programm for cloning data and programms from my SSD to my HDD. Feel free to suggest anything it should be simple and understandable.
https://www.macrium.com/reflectfree
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Just now, GermanPCBuilder said:
Can u give me a short explanation how I can clone just specific programms?
Basically you tell the program which drive you want to clone and where to clone it, then it will do its thing. Simple as that. The spot you clone to will be formatted to match your drive you are cloning from.
Community Standards
"Beast Mode"
So I can only clone a complete drive and no programms alone?
if you want to back up your programs, just copy and paste the folders from one drive to the other. You only really need to worry about "cloning" if its your boot drive.
Community Standards
"Beast Mode"
I want to clone programms from my boot ssd to my storage hdd, still just drag and drop? I want to delete the programm folder on the sdd afterwards to free up some space.
Correct, Just drag and drop them. Then all you will have to do is go to your launch short cut for the programs, right click on then and go into properties and then remap them to the new location so they will launch for you when you click on it.
Community Standards
"Beast Mode"
Ok where can I find the launch short cuts?
Whereever you go to launch the program, be it in your start menu, desktop etc...
Community Standards
"Beast Mode"
2 minutes ago, GermanPCBuilder said:
Just in theory could I put my whole programm and programm (x86) folders to my hdd and delete them on my sdd (boot drive)
Yep, then all you would need to do is change the drive letter on each program. For Example say you have Overwatch in C:/Program Files/Battle.net/Overwatch and you move it from the C drive to the D drive. All you should have to do then is change the C to a D and it should work like normal.
Community Standards
"Beast Mode"
You are the man, thanks very much
np. Ill make a quick short video for you to show and upload it to youtube and give you a link. Should ahve it in like 30-45 minutes I would guess.
Community Standards
"Beast Mode"
No need in that with your explanation I think I will be able to do it.
I only get transfer rates of about 20MB/S and just short peaks of 180MB/S but also 10MB/S peaks why is it behaving that crazy?
If you are going SSD to HDD this is normal, SSD is much much faster. It will take a bit depending on much data you are transferring.
Community Standards
"Beast Mode"
I am transfering about 20GB and it now even drops down to 1MB/S is my hdd rly that slow?
It has to write the data to the platter so it can when its cache buffer is full.
Community Standards
"Beast Mode"
Now I have come to the point where I wanted to delete the programm folders on my sdd but even if I'm not doing anything and want to delete it I get a lot of windows that say that a certain application or programm is running and cant be deleted what should i do? I drag and dropped both programm folders to my first hdd and my second for backup
