I don't think it will harm the PSU in any way
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
https://linustechtips.com/topic/74981-7v-fan-mod/#findComment-1026902
works fine for light loads under 2amps. over that the PSU might feel it is in a bleed
as the sensing sends out a reference and something different comes back.
corsair will not RMA a PSU with 7v damage.. how do i know? hummm. but i was
using over 22amps of 7v current.
https://linustechtips.com/topic/74981-7v-fan-mod/#findComment-1029958
