I currently have a Nvidia GTX 1060 6GB Single Fan GPU that I got from amazon link below:
https://www.amazon.com/gp/product/B01IPVSGEC/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
I have had this card for about 3 months now and it performs great in games except for the temps.
I currently have 2 case fans and the GPU only has 1 fan and under load it gets up to about 87°C on
max settings. I might upgrade to 4 case fans.
This is the case I have:
https://www.amazon.com/Corsair-Carbide-SPEC-02-Tower-Gaming/dp/B00I0MKMG2/ref=sr_1_1?ie=UTF8&qid=1488775733&sr=8-1&keywords=corsair+carbide+spec+02
I just want to know if that's too hot for the card or if I should go through with the 4 case fan thing and see if that might help.
If anyone could help that would be greatly appreciated. Thanks! (:
https://linustechtips.com/topic/748146-temp-issues-with-1060-single-fan/
3 minutes ago, deXxterlab97 said:
I don't really think case fan can help much. Try reinstalling GPU drivers because those temps are quite high
Single fan 1060's run hot.  That's just the way it is.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
2 minutes ago, deXxterlab97 said:
That's great for them, but if you do a little searching you'll find countless people complaining about how hot the single fan 1060 models run.
