Microphone leaking audio issues
Solved by keenhydra,
It might be a faulty headset, have you tried contacting Logitech with this issue?
For all else I'm not sure what you could do, one option I would try is (assuming you use front panel connectors) switch to the back I/O and try it from there or extend one of the cables to the back and keep one on the front panel.
Maybe check if Realtech assigns the right ports for the right job.
If all else fails.. get a separate mic and set that up, might be cheaper than getting a USB headset.
