Hello everyone,
I recently did a Custom build for icemodz,(Custom sleeviing copmany in iceland)
Thought i share the progress with you,
hopefully you like it.
Old-modz_transparent_big_BW-Custom-2-Cus
System specs:
Case - Aerocool Deadsilence Black edition
CPU:Intel 6600K
RAM:G.skill 32Gb Trident Z
MB:Gigabyte GA-Z170MX Gaming 5
PSU:1000W Thermal Take
GPU:Asus 280x Matrix Platinum
SSD:Samsung 950 nvme
The purpose of this Build was mainly to showcase some of the products that are sold over at
http://icemodz.com
Cables,led´s,and barrow watercooling fittings and tubing.
Here are some shots of progress and in the end there will be the HD Shots of the finshed product.
Enjoy!!
First i cleaned all the watercooling gear,like gpu,radiator and reservoir,to make sure no gunk or unwanted particles are get stuck .
and then i did a testfit of the hardware so i can make the minor adjustments that where needed,
(like a cutout for the PSU)
THOR D3SK V2,Asus Maximus VII Hero  ,INTEL4790K,CorsairHX1000i,ASUSR.O.G MATRIX PLATINUM R9 280X  CROSSFIRE,SAMSUNGSSD840 pro RAID0Corsair Force LX 120Gb RAID0,WD 2Tb Black Edition,CORSAIR Dominator Platinum16GB, CUSTOM WATERCOOLED
CUSTOM BUILD 2014
https://linustechtips.com/topic/743855-project-icemodz/
Getting everyting tubed up :)
CUSTOM BUILD 2014
https://linustechtips.com/topic/743855-project-icemodz/#findComment-9425578
Getting the windows cut out,
i kept in mind to hide what i did not want to show,
like the pump on one side and the bottom compartment that houses the cables and such.
CUSTOM BUILD 2014
https://linustechtips.com/topic/743855-project-icemodz/#findComment-9425583
Also for this project the customer had some custom acrylic front panel idea that really put the right touch on the build,
but not without the matt black paint ,since the glossy acrylic look would not had fitted as nicely.
CUSTOM BUILD 2014
https://linustechtips.com/topic/743855-project-icemodz/#findComment-9425588
Barrow fittings ,tubing and custom icemodz sleeved cables with combs are installed :)
CUSTOM BUILD 2014
https://linustechtips.com/topic/743855-project-icemodz/#findComment-9425592
And here are the final HD pictures of the fully finished build.
If you are interested in seeing the Project Icemodz Vol 2.
Head on over to my facebook page and follow me there. @JHPCmods
CUSTOM BUILD 2014
https://linustechtips.com/topic/743855-project-icemodz/#findComment-9425657
