So I just got my new case, received it this morning. I turned off my pc, that until that point was working, and assembled it in the new case. When I pressed the power button it wouldn't start. So I short the power circuit on the motherboard with a screwdriver,  but again nothing happens. Also the motherboard has a power stand by led, and it's on.  Anyone has any ideas?
https://linustechtips.com/topic/743554-pc-not-working-after-changing-case/
Just now, LabRat said:
no proper power or a short.
did you install the standoffs?
They came pre-installed but yes they are on there, also I forgot to mention my motherboard has a green light that indicates stand by power, and that led is on.
11 minutes ago, OliverKunnington said:
So I just got my new case, received it this morning. I turned off my pc, that until that point was working, and assembled it in the new case. When I presses the power button it wouldn't start. So I touch the power circuit on the motherboard with a screwdriver,  but again nothing happens. Anyone has any ideas?
motherboard died due to static electricity?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
1 minute ago, MVPernula said:
Backtrack, have you plugged every powercable in where it should?
Are they in properly?
Replug everything just in case.
I have plugged the 4 pin connector for the cpu, and the 24 pin connector for the motherboard. The fan for the cpu is also plugged in the motherboard, did I miss something?
Front panel connectors?
Desktop specs:
Have you plugged them out and in again? if not; do it.
See if they're properly inserted to the PSU as well.
3 minutes ago, MVPernula said:
What are your specs?
Sorry for the formatting but I am posting it on my phone
Power Supply: NOD PSU-003 620W ATX PSU
Operating System
    Windows 7 Ultimate 64-bit SP1
CPU
    Intel Core i3 2120 @ 3.30GHz
    Sandy Bridge 32nm Technology
RAM
    4,00GB Single-Channel DDR3 @ 664MHz (9-9-9-24)
Motherboard
    ASUSTeK COMPUTER INC. P8H61-M (LGA1155)
Graphics
    Radeon r7 360
Storage
    232GB Seagate ST3250410AS ATA Device (SATA)
Optical Drives
    No optical disk drives detected
Audio
    USB PnP Sound Device
I complete removed the graphics card (it requires a 6 pin connector ) but still nothing.
It really sounds like something is broken.
Take everything out and test it outside you case. If it doesn't start I fear you're out of luck.
26 minutes ago, Maxinfamily said:
Just remove the mobo out of the case and build It outside. Check if everything works, then put It in again.
22 minutes ago, LabRat said:
oliver/max/mvp............ did you read my last post?
I just pulled everything out and tried to start  it and nothing happens ,unless I do something wrong I don't see how I could burn something.
You can short stuff by touch unless you're using wristwraps connected to a PSU and all that, so most likely one of you components died in the process.
My guess is the motherboard.
I thought that my self but electricity clearly passes through, as indicated by the power stand by led. Could it be something else?
