My granddads laptop died on him (we were able to get all the data off it) and he would like a new PC, he loves the fact that in a custom built tower you can custom and upgrade everything, his heart is set on a node 202 case, could someone please create a PC thats at least a quad core with 8gb of ram for under £500 in a node 202 please, im not good with the lower end spectrum of parts!
Thanks in advance
-Scrub
https://linustechtips.com/topic/743527-build-for-gramps/
what will he do with his pc? just youtube and email or anything more intensive?
https://linustechtips.com/topic/743527-build-for-gramps/#findComment-9422407
if he's not a power user this is enough.
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  (£55.05 @ CCL Computers)
Motherboard: ASRock H110M-ITX/ac Mini ITX LGA1151 Motherboard  (£75.50 @ Amazon UK) find out if the bios supports kabylake or get a b250 mobo.
Memory: Team Elite 8GB (1 x 8GB) DDR4-2133 Memory  (£47.79 @ Amazon UK)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  (£69.99 @ Amazon UK)
Case: Fractal Design Node 202 HTPC Case  (£72.95 @ Amazon UK)
Power Supply: SeaSonic 300W 80+ Certified SFX Power Supply  (£43.08 @ Amazon UK)
Total: £364.36
Generated by PCPartPicker 2017-02-25 11:50 GMT+0000
https://linustechtips.com/topic/743527-build-for-gramps/#findComment-9422427
