Fan Controller for CPU Fan
Solved by WoodenMarker,
Fans connected to the motherboard respond to the motherboard fan settings which are usually curves that rely on cpu/system temps.
The Fan Mate 2 provides all the control in the speed control knob. The fan speed is dependent on how far the knob is turned and does not respond to temps. There is a cable from it that connects to the motherboard but that is only for reading rpm.
