Did you download CAM software from NZXT?
Also one random question ... how is it with noise? Can you hear pump noise or water flowing? Or you only hear fans? Just wondering if it's realy more quiet than X31 that I used 1 year ago :)
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/741938-kraken-x52-problems/#findComment-9404675
Yeah i use cam for the kraken and hue+. as for the noise i cant be more satisfied i cant hear the computer when its in silent mode.
https://linustechtips.com/topic/741938-kraken-x52-problems/#findComment-9404678
2 minutes ago, TheEpicDuck said:
I can check.
please do, in BIOS AND with any windows fan tool such as NZXT / MSI / ASUS... you may have.
example: If I lower my RGB fans below 50% power, fan spins but lights turn off, because it has not enough power. So I used my MSI tool to adjust my fan Power between 50% and 100% regarding CPU temps
https://linustechtips.com/topic/741938-kraken-x52-problems/#findComment-9404681
I'm glad to hear that it's as quiet as it can get.
About light problem I can't help you much, since I haven't had X61 or X41 that also have lights on.
I also have HUE+ lightetning and it work just fine with CAM software ... no idea what's causing your problems. But maybe you can write ticket to NZXT. They are very friendly and always trying to help customers.
WD My Cloud 4TB
https://linustechtips.com/topic/741938-kraken-x52-problems/#findComment-9404692
