Hello ,
I have bought a splitter cable and a USB to audio converter with microphone and speaker but when I plug in the splitter cable to my computer the speakers work not the microphone , when I try fixing it their are sometimes sounds that sound like dialup and high frequency sounds that may give up a headache , and I am using a earphone which supports both microphone and audio but when I look at the splitter cable their is a line missing on the jack . is their any way to fix this?
for those who are curious why I have a splitter cable and a USB to headphone and microphone jack because my computer doesn't have a headphone jack .
https://linustechtips.com/topic/739267-splitter-microphone-not-working/
OK took me a little bit to process. So you have a USB to Headphone/microphone, with a splitter male headphone/mic to female, which you plug your head phones into.
So i assume the splitter cable has colours to indicate headphones(Green) and mic(red)
Why do you always die right after I fix you?
