Hi Guys.
I have just got an Enthoo Primo case and will be looking to upgrade my fans. I have a black and white theme so need the fans to match that.
Needs suggestions on 140mm fans for rad and 140mm and 120mm for air flow.
At the moment on the 780t I have the following:
Two 120mm Thermaltake Riing on the rad.
One 140mm Thermaltak Riing as back exhaust
Two Noctua NF A14 as front intake (hidden so the colour does not matter too much).
Thanks guys.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/738426-pc-fan-upgrade/
Corsair has a variety of high quality RGB fans. I personally use the Crystal 460x case so I have a good amount of experience with the SP120 fans. The colors are bright and variable. Unfortunately they are a bit more pricey as I believe you will need a fan controller to change the color.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/738426-pc-fan-upgrade/#findComment-9368070
