Made a build for my friend, any opinions? https://pcpartpicker.com/list/DQxhBP
Main: Gigabyte G1 980Ti, i5 6600k, MSI Z170A M5, 16GB DDR4 2666, NZXT H440, NZXT x61, EVGA 750W G2, Windows 10
Second PC: EVGA Reference GTX 680, i7 2700k, 16GB DDR3, Corsair 300R, Corsair CX500W, Windows 10
Laptop: Acer Aspire 5750G, GT540M, i7 2630QM, 6GB DDR3, Windows 7
https://linustechtips.com/topic/737561-build-for-a-friend/
How about this? He can run it w/o Windows activated
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($329.25 @ OutletPC)
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler  ($24.88 @ OutletPC)
Motherboard: ASRock Z170A-X1 ATX LGA1151 Motherboard  ($91.00 @ SuperBiiz)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR4-2133 Memory  ($50.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.33 @ OutletPC)
Video Card: Zotac GeForce GTX 1070 8GB Mini Video Card  ($369.99 @ Jet)
Case: BitFenix Nova ATX Mid Tower Case  ($28.99 @ NCIX US)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($49.99 @ B&H)
Total: $994.42
Generated by PCPartPicker 2017-02-13 12:12 EST-0500
https://linustechtips.com/topic/737561-build-for-a-friend/#findComment-9358557
1. Not a 1060 3GB. At least a 480 4GB. 1060 3gb is not really a great card for its value
2. Overspent on PSU too much. 450w-550w is enough
3. 212 Evo is nice but there are nicer cooler for the money
https://linustechtips.com/topic/737561-build-for-a-friend/#findComment-9358608
Well in Sweden that build would be like $1600 so yeah.
https://linustechtips.com/topic/737561-build-for-a-friend/#findComment-9358766
33 minutes ago, thebrownieguy said:
Just buy a windows code online, way cheaper!
He will get it from Kinguin.
https://linustechtips.com/topic/737561-build-for-a-friend/#findComment-9358772
8 minutes ago, deXxterlab97 said:
Damn you swedes. Drop to an i5 6600k and keep 1070? How is that then? Also again, don't get 1060 3GB. Get a 1060 6GB or 480 8GB. Even a 480 4GB is bettter
The PSU, Mobo, Cooler, memory, GPU and case are not even available here i think. And the 1060 6GB is $90 more expenisve than the 3GB.
But the Sapphire RX 480 4GB NITRO+ is the same price as the 1060 3GB, is that a better option?
https://linustechtips.com/topic/737561-build-for-a-friend/#findComment-9358828
Yeah it is way better.
Get cheaper PSU then, CX450M would be more than fine
https://linustechtips.com/topic/737561-build-for-a-friend/#findComment-9358831
Just noticed that the RX 480 is $10 cheaper than the 1060.
But what about the Fractal Design Integra M 550W? Is it better? Atleast it's $10 cheaper than the Corsair one.
https://linustechtips.com/topic/737561-build-for-a-friend/#findComment-9358867
