The pre-installed Silent Series R2 fans are pretty good and quiet so you don't need to replace them. I'd suggest using them as an intake in front and install the 140mm Cooler Master back blowing hot air out.
Intel Core i5-13600KF @ 5.4/4.3Ghz (P/E) / Noctua NH-D15 chromax.black / ASRock Z790 PG Lightning / 32GB Kingston Fury Beast DDR5 @ 6400Mhz CL32 / PowerColor Radeon RX 6950 XT Red Devil 16GB @ 2700Mhz / Samsung 980 Pro 1TB / WD Blue SN570 2TB / Corsair RM1000x / Lian Li Lancool 216 / Lenovo G27Q-20 (1440p & 165Hz IPS)
https://linustechtips.com/topic/737043-fan-placement-r4/#findComment-9353614
^ Thats how we setup friends R4. 2 stock ones in front intake and Bitfenix Spectre as rear exhaust. My own R4 has 2 Fractal fans (R3 and R2) as front intakes plus BitFenix Spectre Pro from previous case as rear exhaust. All fans are 140mm.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/737043-fan-placement-r4/#findComment-9357031
