my rig is dh55tc motherboard, core i3 530 16gb of ram and no graphics card, and when i am opening a YouTube video the CPU goes to 99% of usage, i tryed 32 bit i ubuntu and it is the same as windows 10 64 bit, i really need help with it.
thanks to whoever helps me,
Ofir Aviel
https://linustechtips.com/topic/735898-i-need-help-with-youtube/
5 minutes ago, Tauwer said:
not sure but it might be that it is just an old cpu? and the intel graphics on that aren`t the best either (not very sure but if you have money you might want to consider an upgrade)
unfortunately i dont have a credit card yet, but i do have 4.78$ on my paypal account,but what am i going to do until i will get a graphics card?
https://linustechtips.com/topic/735898-i-need-help-with-youtube/#findComment-9342215
My old laptop has the same problem, it starts lagging like hell if watching youtube over 480p. CPU is probably too old. Upgrade might be your only option.
My stuff:
CPU :  Intel i5 8400 | GPU : MSI GTX 970 Gaming 4GB
RAM : 32GB Corsair Vengeance DDR4 @ 3600MHz
Mouse : Logitech G502 HERO SE | Keyboard : Mountain Everest Max w/ Cherry MX Brown
Headset : Beyerdynamics DT990 Pro 250Ω w/ AT2020USB+
Monitor : Acer XF240H @  144Hz
https://linustechtips.com/topic/735898-i-need-help-with-youtube/#findComment-9342226
15 minutes ago, Ofir aviel said:
to upgrade my cpu or gpu?
Cpu I believe. Integrated gpus aren't great either but you can get one for pretty cheap.
My stuff:
https://linustechtips.com/topic/735898-i-need-help-with-youtube/#findComment-9342279
5 hours ago, Ofir aviel said:
what cheap cpu i can get?, i dont have thermal compound so i need to buy one, i can only order on ebay
do you want something that works?
or do you want a cpu that can hold you for like a year?
most likely need to buya new mobo (40 bucks maybe)
and if you have ddr3 you can reuse that ram
https://linustechtips.com/topic/735898-i-need-help-with-youtube/#findComment-9343476
