2011-v3 Cooler Help
Go to solution Solved by lilshaney,
1 hour ago, G27Racer_188 said:
Than we wait for your brother and the intel bracket.
Hello again, I have confirmation that the Intel screws are in fact smaller than the AMD ones and fit the standoffs perfectly! Thanks :)
Hi everyone,
I have a little issue, I have an Asus X99-S motherboard and it has the mounting holes blocked. I am trying to mount a Coolermaster Siedon 120M, I know it does not require a backplate due to the blocked holes and the threaded holes next to the socket but do I need the standoffs (the chunky metal things that normally screw into the backplate)?? Please help I am very confused!
Thanks in advance!
Shane.
SPECS - MOTHERBOARD: ASUS X99-S, CPU: Intel i7 5960X OC @ 4.50GHZ @ 1.20V, CPU COOLER: NZXT Kraken X62 AIO, RAM: 64GB DDR4 Corsair Vengeance LPX XMP OC @ 3000MHZ CL15, GPU: 2x MSI Nvidia GTX 1080 Ti Armor OC Edition W/ Coldzero Backplate in SLI W/ MSI HB SILVER SLI BRIDGE, STORAGE: 250GB Samsung 960 EVO M.2 (Boot), 2TB Samsung 850 SSD (Game Storage) *2x 1TB Samsung 850 SSD (Raid 0)*, 8TB WD Blue (Secondary Application Storage) *2x 4TB WD Blue (Raid 0)*, 500GB WD Green (Web Development), 64GB Sandisk Ultra Fit USB 3.0 (Drivers) *Internally Installed (NZXT Internal USB Hub)*, WIRELESS CARD: TP-LINK Archer T9E AC1900 Dual Band PCI, PSU: Corsair RM1000X 1000W, CASE: NZXT H440 White, LIGHTING: NZXT Hue+, KEYBOARD: Razer Blackwidow Chroma V2, MOUSE: Razer Naga Hex V2, MOUSE PAD: Razer Firefly Chroma Hard Surface.
https://linustechtips.com/topic/734591-2011-v3-cooler-help/
29 minutes ago, lilshaney said:
Hi everyone,
Thanks in advance!
Shane.
Yes you need standoffs. Seidon should come with special standoffs for lga 2011 socket according to the manual
(http://www.coolermaster.com/cooling/cpu-liquid-cooler/seidon-120m/)
They are label with the letter "J".
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9326888
4 minutes ago, G27Racer_188 said:
Yes you need standoffs. Seidon should come with special standoffs for lga 2011 socket according to the manual (file:///C:/Users/GORAN/Downloads/Seidon_120M_Manual.pdf)
Just my luck, it's my brother cooler I'm borrowing a since he has a 1366 socket, the standoffs are different, I'll try find them, thanks alot!
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9326907
We ordered this accessories kit a while ago and it has nothing like the standoffs mentioned in the manual:/
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9326927
Those 4 standoffs in the bottom right look like the standoffs you need.
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9326955
These the ones?
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9326963
1 minute ago, lilshaney said:
These the ones?
Yes, those look correct to me. If you have 2011 MB at hand you can easily try it and see if the thread on them matches the one on the motherboard,
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9326970
They go into the motherboard perfectly but I have a strange feeling these are for a Corsair H100 GTX and won't fit the cooler:/
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9326981
Maybe not...
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9327003
No they are for the Seidon. Corsairs H100 GTX uses 2011 standoffs that have threads on both sides.
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9327013
Just seems a bit weird, I have a bracket for the Siedon 120M here but it is an AMD one just to test the hole size on the standoffs and the screw seems maybe a mm too big, until my brother is home I can't test the Intel brackets actually on the cooler. Just looking inside his desktop the screws seem the same size that is why I'm a little concerned:/
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9327024
Is the seidon currently in use in his PC?
Anyway you need to use screws that came with the cooler, not some others you have lying around.
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9327041
These screws are for the cooler just on the AMD bracket the Intel bracket is currently in his PC so I can't test that until he is home in a bit. I can't see them using 2 different screw sizes for AMD and Intel?
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9327060
Well, they should fit. If they don't then standoffs are fore some third cooler.
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9327085
That's not possible we have only ever owned 120M and H100i GTX
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9327097
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9327128
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9327492
My test computer worked fine in the end, and the temps were great even under 100% load, never exceeded 55c. Didn't think this low end cooler would do so well against a 5930K!
https://linustechtips.com/topic/734591-2011-v3-cooler-help/#findComment-9333706
