Phanteks led strips
Go to solution Solved by stealth80,
yes that's fine I used the same ones
I recently finished my build. I purchased phanteks led strips, but I need to cut them down. I assume you can cut them along the black lines that cross across the strip horizontally on the contacts, I just want confirmation. Thank you
Intel 7700k @stock// Asus rog strix GeForce GTX 1080// Asus rog Z-270E// Phantels Enthoo Evolv// 32gb (2x16) Corsair Vengance LPX// Corsair H100i V2// Samsung 850 Evo 250gb// Seagate BarraCuda 3tb// Corsair RM750i
https://linustechtips.com/topic/733189-phanteks-led-strips/
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/733189-phanteks-led-strips/#findComment-9312444
