Audio jack issue after cleaning!
Solved by Mcmole,
make sure you plugged in the HD Audio cord and not the AC ' 97 cord, they look basically identical.
Also if you happen to have your motherboards user manual check to see if you plugging it into the correct pin set on the motherboard. the book will tell you the position or just check online for your motherboard model and download the manual.
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
