This is my PC, I run games in 4k on a predator x34 21:9 gaming monitor. All the settings on ultra and my card overclocked to 135 for gpu offset and 25 mem clock offset. I also clocked my CPU to 4.9 ghz
I applied new thermal paste to the cpu but when I play a game like gta 5 online for a long time it just freezes and I have to push the power button to boot. Any ideas on whats causing this?
[PCPartPicker part list](https://pcpartpicker.com/list/L8mX3F) / [Price breakdown by merchant](https://pcpartpicker.com/list/L8mX3F/by_merchant/)
Type|Item|Price
**CPU** | [AMD FX-9590 4.7GHz 8-Core OEM/Tray Processor](https://pcpartpicker.com/product/pGrG3C/amd-cpu-fd9590fhhkwof) | $191.98 @ Newegg
**CPU Cooler** | [Corsair H60 54.0 CFM Liquid CPU Cooler](https://pcpartpicker.com/product/Vwdqqs/corsair-cpu-cooler-h60cw9060007ww) | $60.66 @ Jet
**Motherboard** | [Gigabyte GA-990FXA-UD3 R5 ATX AM3+ Motherboard](https://pcpartpicker.com/product/3YH48d/gigabyte-motherboard-ga990fxaud3r5) | $99.89 @ OutletPC
**Memory** | [Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1866 Memory](https://pcpartpicker.com/product/pjp323/corsair-memory-cmy8gx3m2c1866c10r) | $49.99 @ Corsair
**Storage** | [Toshiba 2TB 3.5" 7200RPM Internal Hard Drive](https://pcpartpicker.com/product/fpCwrH/toshiba-internal-hard-drive-dt01aca200) | $67.88 @ OutletPC
**Video Card** | [EVGA GeForce GTX 1080 8GB FTW DT GAMING Video Card](https://pcpartpicker.com/product/qkJkcf/evga-geforce-gtx-1080-8gb-ftw-dt-gaming-video-card-08g-p4-6284-kr) | $649.88 @ OutletPC
**Case** | [NZXT Phantom ATX Full Tower Case](https://pcpartpicker.com/product/FLR48d/nzxt-case-phan001rd) | $116.99 @ SuperBiiz
**Power Supply** | [Azza 1000W 80+ Bronze Certified ATX Power Supply](https://pcpartpicker.com/product/2F2kcf/azza-power-supply-psaz1000a14) | $111.72 @ Amazon
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **$1398.98**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2017-01-29 22:13 EST-0500 |
https://linustechtips.com/topic/730653-pc-overheating-or-freezing/
@Nubaca Did you install the drivers for your GTX 1080? :)
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
Type|Item|Price
Probably instability, try either increasing the vcore slightly (temp permitting) or lower the speed to 4.8ghz
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
I had this problem even before I overclocked my CPU, I've read that the 9590 has a heat problem could it be that I need a new water cooler? With a bigger radiator?
That cooler is weak, the H80 was worse than my 212 evo, try a H100i
Ryzen Ram Guide
26 minutes ago, Nubaca said:
Ok and increasing vcore do you mean voltage? And how do I do that for my CPU? In bios?
by like .025volts at a time, testing each time for stability and heat
Ryzen Ram Guide
1 minute ago, stealth80 said:
by like 0.25volts at a time, testing each time for stability and heat
Did you mean 0.025V? Going up a quarter of a volt is crazy high.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
haha yes, missed a zero :/
Ryzen Ram Guide
Lol good.  I just hope you fix it before the OP fries his CPU. xD
