Wireless Headphones Causing Internet Speed Loss
fojacko
So I bought myself some Corsair Void headphones and their great, but for some reason, when i use them (in wireless mode) on my upstairs PC the speed drops from 30mbps to 4/5mbps. I'd understand a small drop in speed because of interference, but 15mbps?
I am 100% it is the headphones, I have run 11 speed tests and the results are the same each time, 30mbps when the headphones are off and 5mbps when they are on. Is there any way for me to fix this or am i just screwed?
EDIT - if it wasn't obvious i am on wifi upstairs.
EDIT 2 - I have fixed it, i had the wifi adapter plugged in the back of my pc, i unplugged it and put it in the front and im back to 30mbps. I'm presuming having 2 usb dongles using 2.4ghz right next to each other just causes confusion.
My Build
GPU: MSI GTX 1080 ARMOUR | CPU: i7 9700k | Ram: 16gb 3200mhz Motherboard: ASUS Maximus XI Gene | Storage: 2x 1TB NVME 1x 500GB NVME 1x 120GB NVME | Case: Corsair 570X
What router do you have?
