Posted January 22, 2017 Hi! So my mother would like to get a laptop (Under $600 USD) for her work. By that I mean browsing the internet and printing things. She would like a laptop thin and light, and preferably a aluminium body. (Also please no used deals) Thanks! Ion (Main Build) Overall Setup i5 6500 3.2 GHz -Blue snowball (White) thanks goodwill MSI Mortar Arctic -Logitech K120 Asus 1060 6GB Dual -Logitech Daedalus Prime G302 PNY CS1311 120 GB -Mousepad I made in 1st grade with my name on it WD Caviar Blue 1 TB Crucial Ballistix Sport LT White 16GB (8x2GB) 2400 NZXT S340 White Corsair CXM 450W Lenovo H320 (Old Pre-built PC) Possible upgrade for H320 i5 650 3.2 GHz (heh) Xeon X3470 Motherboard unknown Same Motherboard iGPU GT 1030 (MSI Low Profile Half Height) Crucial 240GB SSD Crucial 240GB SSD 6GB DDR3 (4+2GB) 8-10GB DDR3 (4+2+2GB/4+4+2GB) Lenovo H320 case Lenovo H320 case Unknown PSU (210W?) Same PSU (210W?) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 22, 2017 air notebook 13 ? xiaomi Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 22, 2017 Author 3 minutes ago, TechGuy007 said: air notebook 13 ? xiaomi That isn't under 600 though... Ion (Main Build) Overall Setup i5 6500 3.2 GHz -Blue snowball (White) thanks goodwill MSI Mortar Arctic -Logitech K120 Asus 1060 6GB Dual -Logitech Daedalus Prime G302 PNY CS1311 120 GB -Mousepad I made in 1st grade with my name on it WD Caviar Blue 1 TB Crucial Ballistix Sport LT White 16GB (8x2GB) 2400 NZXT S340 White Corsair CXM 450W Lenovo H320 (Old Pre-built PC) Possible upgrade for H320 i5 650 3.2 GHz (heh) Xeon X3470 Motherboard unknown Same Motherboard iGPU GT 1030 (MSI Low Profile Half Height) Crucial 240GB SSD Crucial 240GB SSD 6GB DDR3 (4+2GB) 8-10GB DDR3 (4+2+2GB/4+4+2GB) Lenovo H320 case Lenovo H320 case Unknown PSU (210W?) Same PSU (210W?) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 22, 2017 Just now, QuantumBit said: That isn't under 600 though... the 12.5 inch one is Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 22, 2017 Author 1 minute ago, TechGuy007 said: the 12.5 inch one is Oh you're right sorry, thanks for the input! Ion (Main Build) Overall Setup i5 6500 3.2 GHz -Blue snowball (White) thanks goodwill MSI Mortar Arctic -Logitech K120 Asus 1060 6GB Dual -Logitech Daedalus Prime G302 PNY CS1311 120 GB -Mousepad I made in 1st grade with my name on it WD Caviar Blue 1 TB Crucial Ballistix Sport LT White 16GB (8x2GB) 2400 NZXT S340 White Corsair CXM 450W Lenovo H320 (Old Pre-built PC) Possible upgrade for H320 i5 650 3.2 GHz (heh) Xeon X3470 Motherboard unknown Same Motherboard iGPU GT 1030 (MSI Low Profile Half Height) Crucial 240GB SSD Crucial 240GB SSD 6GB DDR3 (4+2GB) 8-10GB DDR3 (4+2+2GB/4+4+2GB) Lenovo H320 case Lenovo H320 case Unknown PSU (210W?) Same PSU (210W?) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 23, 2017 HP Elitebook Folio G1 You can find them on eBay for under $600. Do not get the 4K display but I do recommend the touch FHD model for the glass alone (IMO). SSD is easy to upgrade. Ive had one for awhile now and I really enjoy it (more so than the XPS13). Great deal at your budget: http://www.ebay.com/itm/HP-EliteBook-Folio-G1-12-5-Touch-Screen-m7-240GB-8GB-Notebook-W0S39UT-/152380363005?hash=item237a93d0fd:g:ApsAAOSwnHZYar~n Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
