Need some help!!! Please n ty!
Go to solution Solved by Droidbot,
3 minutes ago, Saiem said:
So it doesn't let me boot into the bios without clicking on that (pic 1) first but when I do boot into the bios using that in the bios feature there are those two options (pic 2). Also in the save and exit tab there are these two boot override options (pic 3)
Boot to the 'PNY USB 2.0 FD 1100'
Not the one with UEFI before it
Hello
So I was doing a clean install of Windows 10 on a PC that I built. I originally had a trial version and there were issues so I decided to do the clean install. When I attempt to install Windows it gives me an error message saying "Windows cannot be installed on this disk. The selected disk had an MBR partition table. On efi systems, Windows can only be installed to GPT disks". Now I think the solution lies somewhere in the bios with disabling the efi?  However I am quite new to tech and I don't really know my way around. I have a gigabyte ga-h110m-a motherboard. Please have some patience with me when helping, thanks! Also let me know if any further info is needed.
https://linustechtips.com/topic/725069-need-some-help-please-n-ty/
5 minutes ago, Droidbot said:
when you boot into the bios boot menu, the usb disk will have two options: normal and '(uefi)'.
do they appear or just normal
idk
