Hello everyone! I am going to be building my new PC soon, and I would like some feedback on how to hopefully reduce the price of the system. Here are the main concerns. Is the 75hz version of the monitor worth the extra money? A 60hz version is available for 100 dollars less. Anything else I should change? Here is my list: List
https://linustechtips.com/topic/724789-need-help-lowering-costs/
I mean, what parts are you going to get? I can guarantee you're overspending on at least one of them.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/724789-need-help-lowering-costs/#findComment-9221077
It would be helpful of you stated what you plan to buy..
If I've missed where you said this I apologise.
First thing I can think of though as a general tip is many people I know buy overclockable parts such as motherboard and processor when they don't have the other parts required or just don't plan to do it.
It's also due note modular power supplies are generally more expensive when only really making a difference to aesthetic (and also a small difference to airflow if your case doesn't have much space to put the leftover cables
https://linustechtips.com/topic/724789-need-help-lowering-costs/#findComment-9221085
what are you starting with? what is your budget?
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/724789-need-help-lowering-costs/#findComment-9221095
