https://www.pccasegear.com/sc/5PLY
i am looking to build my first pc. Above is the list of parts that some of my friends have helped me create. My budget is around $1500 and i was wondering if anyone could review/improve this build so i get the best performance for my price range. Thanks for any input.
https://linustechtips.com/topic/723882-my-first-pc-build/
https://linustechtips.com/topic/723882-my-first-pc-build/#findComment-9210451
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: ARCTIC Freezer 13 36.4 CFM CPU Cooler  ($25.88 @ OutletPC)
Motherboard: MSI Z170A KRAIT GAMING 3X ATX LGA1151 Motherboard  ($122.99 @ SuperBiiz)
Memory: G.Skill Ripjaws 4 series 16GB (2 x 8GB) DDR4-2400 Memory  ($96.88 @ OutletPC)
Storage: Kingston SSDNow UV400 240GB 2.5" Solid State Drive  ($67.88 @ OutletPC)
Storage: Toshiba 3TB 3.5" 7200RPM Internal Hard Drive  ($84.99 @ B&H)
Video Card: Asus GeForce GTX 1080 8GB STRIX Video Card  ($678.99 @ SuperBiiz)
Case: BitFenix Nova ATX Mid Tower Case  ($37.99 @ NCIX US)
Power Supply: SeaSonic G-750 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($78.28 @ SuperBiiz)
Total: $1423.87
Generated by PCPartPicker 2017-01-16 11:00 EST-0500
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/723882-my-first-pc-build/#findComment-9210453
Total: $1423.87
He is in Australia, not the USA.
https://linustechtips.com/topic/723882-my-first-pc-build/#findComment-9210470
save a bit of cash by switching to a seasonic s12ii 520 watt
use the saved money to slot in a i5 7500
get a crucial mx300. its a bit cheaper and has double the capacity.
for a bit more cash consider moving to a corsair 100r/200r
if (you want to reply) {
 USE THE QUOTE BUTTON
else {
 DONT
https://linustechtips.com/topic/723882-my-first-pc-build/#findComment-9210485
Shit sorry.
https://linustechtips.com/topic/723882-my-first-pc-build/#findComment-9210494
