Hi Friendly Folks!
I've been using a Logitech G910+ for about 2 years now. Decent keyboard. But I'm finding the build quality of the keycaps to be extremely poor. The backsides that hold the keycaps to the mechanical switches keeps breaking on multiple keys, causing them to pop off, and be unable to remain attached
So far this has happened to my CTRL key, my Windows key, my Escape key and a few of the numbers on the number row.
I don't want to replace the whole keyboard for just keycaps. Does anyone know a good place to get replacement keycaps? I don't mind replacing every single key if it means upgrading to a better quality keycap. Right now because of this experience i am not convinced that Logitech has quality keycaps.
also: would the Razer Black Widow ultimate keycaps fit on the logitech? (i have a broken one in storage that I could switch the caps for if they fit)
Thanks for the help/advice everyone :)
Quote
"Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so." - Douglas Adams
System: R9-5950x, ASUS X570-Pro, Nvidia Geforce RTX 2070s. 32GB DDR4 @ 3200mhz.
https://linustechtips.com/topic/723873-logitech-g910-keycaps-keep-breaking/
The caps from the razer should fit fine. (They should both have the T style connection)
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
