Help with keyboards pls
Solved by Aleks NE,
I would recommend the Razer Switches, they are similar to the blue but i wouldn't call them knockoff as the are some diffrences. But Cherry MX Blue switches are also fantastic i personally prefer the razer switches and would 100% recommend you the Razer Tournament Edition keyboard, However its not backlit so it would take some time getting used too if your coming from a backlit one.Or you can spend 100 more and get the backlit one.
