So I have one of the old K95's, with red switches, blue led's, and recently I discovered the USB on my Audio mixer acts as an input as well (I thought it was only an output) and I plugged it into my keyboard, now the mixer runs fine, but my keyboard stops responding? No key input works, at all. Any ideas as to why?
EDIT: Also... It works fine until I play audio, then the keyboard stops working
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
https://linustechtips.com/topic/723063-corsair-k95-problem/
1 minute ago, pwn_intended said:
Does the KB have a USB passthrough or a hub? As in do 2 cables plug into your mobo from it or just one?
It's a passthrough, two cables, both going into USB 3.0
https://linustechtips.com/topic/723063-corsair-k95-problem/#findComment-9202063
hmmm, then plugging something into the port shouldn't affect the KB at all.
The only thing I will recommendd then is to plug them into usb 2 ports instead. Sometimes devices glitch out when using USB 3 ports.
When in doubt, re-format.
https://linustechtips.com/topic/723063-corsair-k95-problem/#findComment-9202077
I can't... My USB 2.0 ports don't work anymore.. Lel rip
https://linustechtips.com/topic/723063-corsair-k95-problem/#findComment-9202080
Yea, then there's a good chance you brokened (its a word ok) more than just the usb2 ports....
GL.
https://linustechtips.com/topic/723063-corsair-k95-problem/#findComment-9202093
