just fitted my h100i to my haf912 :)
are these good load/idle temps?
cpu: 3570k at 4.7 ghz at 1.4 v
i5 3570k @4.6 ghz | Cooler Master hyper 212 EVO | Asus DCUll 780ti @1200/1400 | 1 TB Seagate Barracuda | Corsair HX 750 80+ gold | 8 GB Kingston HyperX Blu | Cooler Master haf 912 windowed edition |  2 x crappy  4:3 monitors (1024x1280) | ASUS VG248QE 1080p 144hz monitor|
#KILLEDMYWIFE  #POOKLO
https://linustechtips.com/topic/72161-good-temps/
Looks about right. You feed your CPU 1.4V though?
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/72161-good-temps/#findComment-988021
Looks very...average...
lol, but better then 90 on air :P
https://linustechtips.com/topic/72161-good-temps/#findComment-988030
Turn that voltage down as much as you can. 1.4 is pretty damn high. Won't get much life out of that CPU compared to others. And also, your temps are fine, I get higher idle temps than you and I have a custom loop, my load temps are a lot better though but still yours a good especially for 1.4 V core.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/72161-good-temps/#findComment-988032
only on water.
https://linustechtips.com/topic/72161-good-temps/#findComment-988033
upgrading next intel release.
https://linustechtips.com/topic/72161-good-temps/#findComment-988035
thanks all. Time to go play bf4 without worrying about my shit melting!
https://linustechtips.com/topic/72161-good-temps/#findComment-988106
