Posted January 6, 2017 I am currently looking for a cheap FHD monitor that will replace my dying HD monitor. This BenQ GW2270 VA LED in what I think fit on my budget. Is it good for gaming and photo editing? Any thoughts about this product? Thanks. Contestants: BenQ 22" GW2270 LED Samsung 22 S22 F350FHE LED Viewsonic 22 VA2259SH LED LG 22 22MP67HQ LED IPS frameless Monitor will be used for: Gaming Photoshop Premier Programming MS Office Updated the question and added choices. The choices are the only available(and at my budget). This is what my monitor looks like Spoiler I currently play PUBG, help me get chicken dinner Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 6, 2017 It seems decent, but it only has a VGA port and a DVI port. DVI might be fine but hdmi is a good choice. My second display is a BenQ GL2460hm and it's pretty good for a 60hz. You should check it out. https://www.amazon.com/dp/B00IKDFL4O/ref=cm_sw_r_cp_api_21UByb1TDP6WJ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 6, 2017 Author 9 minutes ago, RoboTechnal said: It seems decent, but it only has a VGA port and a DVI port. DVI might be fine but hdmi is a good choice. My second display is a BenQ GL2460hm and it's pretty good for a 60hz. You should check it out. https://www.amazon.com/dp/B00IKDFL4O/ref=cm_sw_r_cp_api_21UByb1TDP6WJ unfortunately that model is not available in my place I currently play PUBG, help me get chicken dinner Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 6, 2017 Author Updated the question and added choices. The choices are the only available(and at my budget). I currently play PUBG, help me get chicken dinner Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
