Need a help with power supply
Go to solution Solved by Aniallation,
4 minutes ago, Ruwan969 said:
I need a power supply so i can get corsair 750w psu if i spend little bit more like 50$ i can get Rosewill Capstone 1000w gold psu... but i don't know any think about Rosewill Capstone can some one please help me out....
What kind of Corsair 750W? There's many different models.
Rosewill Capstone is a very solid PSU, made by Super Flower (top tier OEM like Seasonic)
Whats your budget?
go for a Evga G2/G3, Corsair RMx/RMi if you can afford. Also what parts are in your build? 550 watt should be enough for most builds.
If youre on a tighter budget a CX450M or 550 watt version, or a Seasonic M12II/S12II would be good.
"Rawr XD"
3 minutes ago, RKRiley said:
Whats your budget?
yes but what if my only option those two...
(1) Gigabyte GA-Z170X-Gaming 7
(2) G.SKILL Ripjaws V Series 16GB
(3) WD's Red 4TB hard drive
(4) evga gtx 1080
(5) SAMSUNG 960 EVO M.2 500GB
(6) corsair CX 750M Power Supply
(7) Intel Core i7 6700K
(4) evga gtx 1080
They're both overkill honestly, I'd choose neither and get a different one.
But if theyre definitely the only 2 options, the CX750M, assuming its a grey label, will be just fine.
Capstone is much better than CX.
"Rawr XD"
Thats true but the CXm will do just fine. If he wants best quality then the capstone would be a better choice (all be it, only 1 tier better)
I personally don't see the point in paying an extra $50 to go up 1 tier. Especially when it could be changed to a tier 1 RM550x for the same price, if not cheaper.
Unless they plan to SLI, upgrade, and/or overclock in the future. With the system as-is, quality over quantity for the PSU.
Keep in mind Capstone comes in lower-wattage variants as well.
"Rawr XD"
He's already said that those 2 are his only options (for whatever reason)
Comes down to OP's choice really, both will be good for the build, but is it worth it to him to spend $50 for a bit better quality and unneeded wattage.
