Gpu doesn't sit flush with case mount
Go to solution Solved by Godlygamer23,
1 minute ago, DontHitMeMid said:
https://i.imgur.com/oM7dabd.jpg
ye the link shows which slot I'm putting it in
Can I see the card at the slot location?
Can you take a picture and post it here? If you say that it's not sitting flush with the case, are you sure the card is actually in the slot?
https://i.imgur.com/V2N9ZQJ.jpg
link above shows when the card is fully in (soz for shit photo but hope it's enough)
Is it seated in the PCIe slot?
6 minutes ago, DontHitMeMid said:
heres a pic of it in the slot (pushed down quite hard).  https://i.imgur.com/IgBbMKS.jpg
I don't think it's seated down all the way.
Just now, DontHitMeMid said:
I've managed to screw it in lightly just to hold it in place, should I boot my pc up to see if it's connected?
Yes, that would be a great idea.
Can't seem to find where to plug the actual gpu in, looked at diagrams but can't see shit.
The GPU goes in the slot that you connected it to. What is the blue latch for?
I'm talking about the PCI express cables
The power supply cables should be labeled VGA or something similar. What power supply are you using?
Is this a pre-built PC?
Ye
If the power supply has "enough" wattage, it should come with at least one six pin connector.
Hmm looks like  buying a new power supply.
Still though, I would advise you to check to ensure that the card is fully seated in its slot.
What is that blue latch for on the motherboard?
seems to be connected to the fan cooling the cpu.
The angle made it look a bit odd. But yeah, it's AMD's mechanism for mounting their stock coolers.
ya reckon i should just buy a new case and power supply? possibly even a cpu.
I would just stick with buying a new power supply for now, unless you think you need a new case. The CPU is likely sufficient for the 1050 Ti.
