So i was wondering, would it be easy to upgrade my HP PC? Its a I3 has 4gb ram and no graphics card so i was planning on adding a gtx 1050 and 8gb ram so i can play some games on it but im not sure if/how it would work can i get some help?
PC: http://h20564.www2.hp.com/hpsc/doc/public/display?docId=c02865855
I was also thinking of just building a PC instead but i currently only have enough money for the graphics card
All i plan on doing is playing games such as CSGO, GTA, Fallout, skyrim and a few others
https://linustechtips.com/topic/713124-help-with-upgradebuild/
On 27/12/2016 at 9:52 PM, deXxterlab97 said:
You're welcome
When i boot the PC now it just shows the bios and doesnt load windows? Why is this?
Edit: if I use the graphics from the CPU/mobo it boots to windows but windows says " an error occurred we will restart for you", but doesn't restart
https://linustechtips.com/topic/713124-help-with-upgradebuild/#findComment-9113474
