Please Help!
I installed a Brand New Samsung 850 M.2 ssd into my asus laptop and cloned my boot partition over to the new ssd. Now when I boot into the ssd the screen continuously flickers and I am unable to do anything.
I need both the hdd and the ssd to stay in the computer.
IM BACK BABY
https://linustechtips.com/topic/712762-screen-flickers-after-ssd-clone-help/
If you boot off the original HDD does it still flicker?
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
4 minutes ago, kurtstir said:
Nope on the original right now
Try doing a fresh install, Probably the cloning process just messing up.
1 minute ago, kurtstir said:
Its preinstalled windows so is would I just try recloning?
You can try but it may just cause issues again. Fresh install is always recommended because cloning doesn't always work right.
Any way to get a key for free its an asus laptop
IM BACK BABY
14 minutes ago, kurtstir said:
Not illegally*
It has a key its likely built into the bios if it not on a label attached to the laptop somewhere.  You can also try something like https://www.magicaljellybean.com/keyfinder/ to find your key.
