So the reason I'm not putting this in GPU help is because I think other stuff might be it. So recently I got a new PC and yesterday I added a GPU (gigabyte 1050 ti) then it wasn't displaying to my (old) so I had to change something in the BIOS. So once I had finally got the PC up and running in download geforce experience, updated the drivers (I did this about 5 times again after the problem) then I hopped into a game only to find games running worse than my integrated graphics 530. I've disabled integrated graphics in the control panel only for it work even worse. I've got a decent PSU (I only got it a few weeks ago) 550 watt Corsair vs series and I don't think it's my HDD either. I've looked everywhere and I don't know what to do (it was my first PC build) specs are as followed:
Intel core i3 CPU
MSI b150m pro VD MOBO
Gigabyte gtx 1050 ti windforce 4gb GPU
8 GB hyperx fury RAM (1 stick)
Western digital blue 1 TB HDD
Thermal take versa h24 case
Win 10 pro 64 bit OEM
So if you know what to do please say and any help is appreciated. Thanks.
https://linustechtips.com/topic/712220-gpu-problems/
1 hour ago, MVPernula said:
Welcome to the forums!!
First things first:
Did you plug the video cable into the GPU?
Oops. HAHa I don't have a monitor (I'll be getting a fancy AOC monitor soon though) with HDMI on so I plugged it into my TV and I just see FPS: 100+. Haha. Thanks a lot though :) !
https://linustechtips.com/topic/712220-gpu-problems/#findComment-9088342
