I'm wanting to put some white light in my case to show off my new motherboard, AIO, memory etc when I get them in the new year. I'm tempted to get a NZXT Hue+ so if I decide in future to go with a different colour I can change it, but I thought I'd ask anyway if anyone has any recommendations for pure white LED strtips as opposed to the more expensive Hue+ system.
I spend too much on my PC. Then I spend even more on my Sim Rig. Damn, this stuff's expensive.
https://linustechtips.com/topic/711611-white-led-strip/
i got these for NZ$15 to replace my broken Phanteks LED and they are so much whiter than the Phanteks
https://www.pbtech.co.nz/product/SEVCLR0019/Colour-Rig-LED-Strip-Light-White-36-pcs-Lamp-Beads
NZXT has a LED strip that is braided and looks to be much better quality, I didnt get it because it requires a PCI slot and the power lead is too short.
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/711611-white-led-strip/#findComment-9082977
  • 1 month later...
Hey @DELTAprime we have a dual LED solution coming very soon which will be RGB and a pure white LED in the same strip. You can also check out our single LED white strips.
You should be seeing YouTube videos on the RGB-W strip popping up soon. :)
https://linustechtips.com/topic/711611-white-led-strip/#findComment-9308061
