Hey guys im not an expert about these things so here's my question. If I already bought a assembled computer with liquid cooling ex (ibuypower etc.) do i need to set it up or i just open my pc and just do my own thing and the liquid cooling starts automatically? I'm sorry I'm not good in english.
https://linustechtips.com/topic/71146-wataaa-cooling-liquid-cooling/
Not sure about iBuyPower but other companies usually ship the PC fully assembled inlucluding the coolant in the loop. If this is not the case with your PC it should have warnings with it or in an email invoice etc, although you can always just look inside reservior :)
Oh okay! Thanks. I just know anything about water cooling.
no its a closed loop which means it comes from corsair filled and you can not add or change the fluid unless you void your warranty
 CPU: i5-6600k MOBO: ASUS Z170 Pro Gaming RAM: G.Skill 16GB 2800Mhz 15-15-15-35, GPU: Sapphire R9 290 SSD: Samsung 840 250GB HDD: Seagate Barracuda 2TB x2, Cooling: EK supremecy EVO ,EK-FC R9 290X with backplate, XSPC EX240 Crossflow & Alphacool UT60 240mm, XSPC D5 Bayres w/ Alphacool VPP655, 7/16-5/8 Compressions/Tubing, Noctua NF-F12 x4 PSU: Silverstone Strider Plus 850W Case: Nanoxia Deep Silence 1 http://valid.x86.fr/8g2m02
So after i bought the assembled pc i just Start my PC and do my own thing? Thanks!
Thats exactly right as it is all built together and you should just have to plug it in and turn it on
