Please help with some advice!
Solved by AdamBo,
14 hours ago, Spudbilly said:Do you know if your sim games would scale well with sli for your 1060. If your run a high resolution triple monitor setup...your gpu could be a little bit of a problem.
Yeah GTX 1060 apparently is not SLI compatible (I have not had a good look but I don't think mine has the bridge ports)... its definitely a mistake and I wouldn't recommend it.
I guess the aim is to somewhat future proof with the motherboard/ram and cpu even if I have to upgrade or trade graphics cards down the track to a better version or SLI version
