Pretty sure this is the right forum.
SO...trying to setup internal IP camera for my home, but no notes in the box and all help I can find is for windows.
I'm using Mac.
So, got the camera powered on and have no idea where to go from here and can't find anything useful.
Anyone got any ideas?
https://linustechtips.com/topic/705880-ip-camera-issues/
IP scan your network and look for ip's you've not encountered.
http://angryip.org/download/#windows
If you find one, try browsing to it. Ip cam should have a web page where you can view its video feed.
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
https://linustechtips.com/topic/705880-ip-camera-issues/#findComment-9018323
2 minutes ago, redanalog said:
UPDATE:
its a szsinocam SN-IPC-5033SW-Wi-UK
https://www.ispyconnect.com/man.aspx?n=Sinocam
Ip should be the one you found via angry ip scanner or whatever your dhcp server (most likely your router) has given to the camera. Router is most likely at 192.168.0.1
https://linustechtips.com/topic/705880-ip-camera-issues/#findComment-9018344
13 minutes ago, redanalog said:
A note on the box says IPADD 192.168.1.100
Could the fact my router is operating in 0.(1-255) range be affecting this?
Yes, try connecting with a straight cable from a laptop / pc to the camera. You can not have another internet connection aswell btw (so disable wifi)
https://linustechtips.com/topic/705880-ip-camera-issues/#findComment-9018780
so i got to manually assigning an ip and finally got to the screen
issue now is that the camera doesn't appear to be working with mac os well.
There is a .exe that needs to be installed to communicate with the camera.
Got a windows VM running now but it is working from 10.0 range (10.0.2.15)
Anyone know how to get that sorted out?
https://linustechtips.com/topic/705880-ip-camera-issues/#findComment-9021676
Go to network settings and manually set an IP address in the same range.
https://linustechtips.com/topic/705880-ip-camera-issues/#findComment-9023368
