Help me with memory [again]
Go to solution Solved by luigi90210,
31 minutes ago, garukno said:
so it only support 2133?
but if i buy 2400 memory i can still use it on 2133 speed right?
no your board supports 2400mhz so you're good on support but yes if you bought a board that only supported 2133, you can use 2400mhz ram in 2133mhz mode
so i done some research on my cpu which is AMD A8-7600, that is performance is much better with high speed memory so i decide to buy a 2400MHz memory
between these 3 which is more worth it?
G.Skills RipjawsX 2x4GB 2400MHz - http://www.gskill.com/en/product/f3-2400c11d-8gxm
Team DARK 2x4GB 2400MHz - http://www.teamgroupinc.com/en/product/MEMORYMODULES/OVERCLOCKING/DDR3/DARK DDR3
Team Vulcan 2x4GB 2400MHz - http://www.teamgroupinc.com/en/product/MEMORYMODULES/OVERCLOCKING/DDR3/Vulcan DDR3
and is a8-7600 compatible with 2400MHz memory?, because i read a lot of this cpu review, and none using a 2400MHz memory when testing
and what is XMP?
https://linustechtips.com/topic/705134-help-me-with-memory-again/
2 minutes ago, Droidbot said:
Which motherboard? Memory compliance comes down to the board, not the CPU in most cases.
ASRock FM2A68M-HD+, so cpu doesn't matter with memory speed? as long the motherboard support it?
1 minute ago, Rohime said:
XMP is pre-configured memory profiles for overclocking - allows you to select a memory overclock profile directly in the UEFI/BIOS.
can i use XMP on AMD motherboard?
Yes, you can use 2400mhz memory.
- Dual Channel DDR3 Memory Technology
- 2 x DDR3 DIMM Slots
- Supports DDR3 2400+(OC)/2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memory
- Max. capacity of system memory: 32GB*
- Supports Intel® Extreme Memory Profile (XMP) 1.3 / 1.2
- Supports AMD Memory Profile Technology (AMP) up to AMP 2400
idk
to answer both questions
yes and yes you can use XMP on AMD boards but double check your board
