I'm not sure if this is permitted (please tell me if its not) but can someone make the most expensive build ever including monitors and everything? I was doing it earlier and I got all the way to like 7.7K US dollars.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/704951-most-expensive-build/
not this again....
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/704951-most-expensive-build/#findComment-9008621
Just now, deXxterlab97 said:
Just add as much monitor you wish and you will have it
good idea.
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/704951-most-expensive-build/#findComment-9008625
2 minutes ago, FloRolf said:
not this again....
Not allowed?
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/704951-most-expensive-build/#findComment-9008637
1 minute ago, Himommies said:
Just add a lot of monitors to this
https://pcpartpicker.com/list/XxQ3gL
Why are those CPU's so expensive.. And also the intel SSD's???
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/704951-most-expensive-build/#findComment-9008677
22 core cpus man
oh my
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/704951-most-expensive-build/#findComment-9008684
Just now, Himommies said:
With hyperthreading
even better
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/704951-most-expensive-build/#findComment-9008694
