Need help with fan placement
So, I have a Corsair Carbide 400C with three AF120mm Quiet Fans in the front hooked up to Corsair Carbide's 100R Silent Edition's fan controller.
When I am gaming I think my GPU is thermal throtteling...
While playing Fallout 4 for a good time (around 2-3 hours) the fps starts to drop from 60 fps to 30-45fps which is annoying...
the fans in the front are spinning max, my CPU is cooled by a Corsair Hydro h80i v2 with two SP120mm PWM Quiet fans, profile in Corsair Link of Performance for max airflow through the rad.
my GPU is a Palit GTX 970 with Palit's referance cooler.
How can i get better airflow? I have following fans laying around which I can use: 2x Corsair SP120L, 1x Corsair AF120L, 1x Corsair 140L.
My GPU is hitting 77 degrees max.
I have place in the top for some fans.
i hope someone can help me out! Thanks.
https://linustechtips.com/topic/704723-need-help-with-fan-placement/
77c you're not thermal throttling on the gpu. What are cpu temps like?
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
If your CPU rad is an output, then there's not much you can do. Since if you have 3x120mm AF in the front, that's the most you can input from that side with the 400C case. At what fan speed % is your gpu? Also it seems a bit odd that it takes that long for you to thermal throttle with your GPU.
What kind of CPU temperatures are you getting at the point when your FPS starts dropping, since Fallout 4 is quite CPU heavy game, it might be that if you have old thermal paste or the case air gets so much hotter overtime that your radiator can't keep your cpu cool enough.
CPU: i5 6600k @4.5GHz | GPU Zotac Amp! 1070 | RAM: Corsair vengeance 16gb | Storage: Corsair Force LE 240gb +480gb | Case: Corsair Carbide Clear C400 | PSU: Corsair RM650x | Cooler: H110i GTX
Thanks for such a detailed answer.
My CPU temps are ish 50-58 when the fps drops.
the coolant is around 37 degrees.
The rad is in the back exhausing air, I may actually putting the rad in the front again for intaking fresh cold air.
the Thermal paste is 2 weeks old, and my GPU fan % is at around 50-78% (auto).
My CPU is a i3-6100 which actually keeps up, I play Fallout at the max settings possible and have stable 60fps, from time to time...
17 minutes ago, Swinzon said:
snip
Well. The temps don't seem to be the issue.
What I've noticed when playing F4, modded albeit, is that at certain points in the game it is much more demanding than in other places. But that still shouldn't explain why you're noticing these drops later on. But is the problem that you only have issues after approx 2 hours. Or are these issues or framerate drops present as soon as you start playing and are they only bound to lets say open areas with lots of grass or water or smoke?
One long shot I could think is that, you might be running the game from a HDD, and the bay is located below the shroud? So after 2-3hours of using the HDD constantly it starts to heat up. This you could try to see if it is the case by removing the side panel and seeing if the problem still persists. But since the cable management area is quite small in 400C, I recommend removing the panel while you're pc is turned of so you won't yank the cables while the pc is running.
And the best bet at this point is to have some sort of overlay on, let's say riva turner. And see what kind of GPU and CPU utilization you have during these fram rate drops. It might be that in high AI or physics situations it might be that your CPU is getting overwhelmed, or in closed quarters with smoke and water or open area with grass and water might instead overwhelm your gpu both of which result in framerate drops.
Thanks. I am the game from a SSD which is installed in the 3.5" bay, where I also have a fan blowing air directly on it.
The SSD is max 37 degrees...
But I`ll fire up the game now and see.
Are you sure it's not just FO4? FPS drops significantly in the city or when fog rolls in (drops about 50% for me). To fix this turn down the shadow view distance and god rays.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
