Hi
I'm needing a laptop for my college work, I'm learning ICT so I need a laptop that can handle databases, web development, graphics design, programming and so on.
For that reason, it also needs to be portable with good battery life (above 4-6hrs, 15.6" or smaller).
I would like to spend under £600(ish), as I'm still a student (low income).
I've found this laptop for £599.99 (down from £699.99), the spec's are:
http://www.ebuyer.com/757793-acer-aspire-f-15-laptop-nx-gd6ek-009
CPU: i5-7200U
GPU: GTX 950M 4GB
RAM: 8GB DDR4 (Expandable to 32GB)
HDD: 1TB 5400rmp
SSD: 256GB ATA/600
Battery:
  • 6 Cell Lithium Ion (Li-Ion) Battery
  • 90W Adapter
  • Capacity 2800 mAh
  Screen:
  • 39.6 cm (15.6") Active Matrix TFT Colour LCD
  • LED Backlit
  • Resolution: 1920 x 1080
  Dimensions
  • Height 23 - 28.45 mm
  • Width 381.6 mm
  • Depth 259 mm
  • Weight (Approximate) 2.23 kg
Is this any good, or do you know of any better choices?
Many Thanks
Liam
https://linustechtips.com/topic/703857-im-i-choosing-right/
Development requires very little in terms of raw power. that laptop is more than enough.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/703857-im-i-choosing-right/#findComment-8996525
