Noctua, Corsair SP120 quiet edition
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/703822-h115i-stock-fan-replace/#findComment-8996115
Noctua Nh-D14 of the 120mm equivalent, I dont know which one the h115i uses. I have 3 NH-D14s in my mother's computer (small microATX case, Raijintek StyX) and an NH-u12S with a noctua 120mm fan and it's near silent. CPU stays under 35 under load, and only one fan is pushing the air through the fins. So, I recommend anything noctua
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
https://linustechtips.com/topic/703822-h115i-stock-fan-replace/#findComment-8996123
The NH-D14 is a heatsink. You're either referring to the NF-P14 or NF-A14.
NF-A14's are an excellent replacement for the stock AF140L's.
https://linustechtips.com/topic/703822-h115i-stock-fan-replace/#findComment-8996134
Oops, you're right. NF-A14's indeed.
https://linustechtips.com/topic/703822-h115i-stock-fan-replace/#findComment-8996143
