So I am working on finalizing my PC parts. I am trying to cut down the cost a little bit while keeping performance in tact, I left the OS and monitor in as I am counting it as the cost of my PC.
https://pcpartpicker.com/list/84Fnyf
Q
Here is a little reasoning as to why I am upgrading:
I currently run on a acer laptop with a 940m, and a 15-2000 or something and it is simply not cuting it. Its a great PC, but when im home I need something more powerful.
Price im hoping to get for both parts and os/monitor:
$1000-$1200
https://linustechtips.com/topic/702478-need-help-with-pc-build/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($220.98 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ B&H)
Motherboard: Gigabyte GA-Z170X-Ultra Gaming ATX LGA1151 Motherboard  ($149.99 @ B&H)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($79.99 @ Newegg)
Storage: Crucial MX300 275GB M.2-2280 Solid State Drive  ($70.98 @ Directron)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.78 @ OutletPC)
Video Card: MSI GeForce GTX 1070 8GB Video Card  ($440.99 @ SuperBiiz)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($49.99 @ B&H)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($90.72 @ B&H)
Wireless Network Adapter: Gigabyte GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($29.99 @ Newegg Marketplace)
Monitor: Acer G257HU smidpx 25.0" 2560x1440 60Hz Monitor  ($233.99 @ Jet)
Total: $1514.38
Generated by PCPartPicker 2016-12-05 12:36 EST-0500
https://linustechtips.com/topic/702478-need-help-with-pc-build/#findComment-8979069
Q
$1000-$1200
Parts are solid, but I'd take another look at that case and PSU.
also, you can get windows a lot cheaper elsewhere, use the cash you save on the above.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/702478-need-help-with-pc-build/#findComment-8979077
Also there are better mobo choices, the Z170 Extreme 6 is to me a clear choice for 150USD motherboard.
https://linustechtips.com/topic/702478-need-help-with-pc-build/#findComment-8979166
Imho. The case is fine. I agree with the asrock z170 extreme 6. And it is always better to get a more efficient gold rated PSU. Its worth it. Especially when overclocking, which I imagine you want to do. Fyi....the ddr4 3000 memory  and cheap PSU could hold back your max overclock.
CPU: Ryzen 7 2700x cooled by Pure Rock Slim // RAM: Gskill Flare X 3200mhz CL14 2x16 32GB// GPU: Powercolor Red Devil RX 6650 XT 8GB// Motherboard: ASRock B450m Pro 4 // PSU: Seasonic G550 Gold 80+ // Storage: 4TB pcie nvme game drive, 512 GB m.2 sata3 OS Drive, 4 TB WD Red HDD // Monitor: Samsung S22D300 21.5" 1080p 60Hz, MSI 27" 1080p 144hz Freesync 1ms display // Peripherals:  Logitech fancy shmancy keyboard and moise with rgb and gaminess stuff, very fancy | Kingston HyperX Cloud Core headset
https://linustechtips.com/topic/702478-need-help-with-pc-build/#findComment-8979383
On 12/5/2016 at 0:59 PM, begadelavela said:
change psu and if u can get better case and it looks perfect build.
I have taken the feedback and have made changes to the PSU, Case, Cooler and Memory. Thoughts?
New Parts:
CRYORIG H7 49.0 CFM CPU Cooler
Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory
Corsair 200R ATX Mid Tower Case
EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply
I also added speakers and keyboard to my price:
Corsair STRAFE Wired Gaming Keyboard
Logitech Z200 0W 2ch Speakers
https://pcpartpicker.com/list/MZrNxY
https://linustechtips.com/topic/702478-need-help-with-pc-build/#findComment-8993301
6 hours ago, D3faulT said:
Looks good to me. If you want you can still do ddr4 2400mhz or up to 2666mhz. Above that it really is dependent on how good that CPUs memory controller is while also doing a high overclocked(aka 4.5hgz+.
I would say a descent overclock combined with ddr4 2666 is achievable, but the performance gains from memory are minute compared to the performance gains achieved with increasing clock speeds.
If you want to keep the 2133 ram...you won't notice the difference.
https://linustechtips.com/topic/702478-need-help-with-pc-build/#findComment-8995276
