Hi,
I'm currently using VB.net, on Microsoft Visual Basic 2010 Express, to create a program for a small business, as a school project
In a form named MainUI, and I'm trying to display a text file in a multiline textbox named notes, I want the user to be able to read what is in the textfile and edit the contents through the same textbox with a button underneath named savetext. However I am unable to make this work and am wondering if anyone could help me or direct me to a webpage that already has an explanation.
Thanks in advance
WaspishVyper
https://linustechtips.com/topic/7003-vbnet-help/
  • 2 weeks later...
Hi Im doing the exact same thing!! What business are you doing? I've gone with a hotel.
Saving a file is easy you need to open one first
FileOpen(1, filedirectory, openmode.random, , , filesize)
if you make a random access file you get more marks - so my teacher said anyway :)
the saving is fileput (1, structurename, len(structure)
1 is just a file reference :)
https://linustechtips.com/topic/7003-vbnet-help/#findComment-91523
Thanks for the help, I'm doing it for a bunch of PHD students that work for my mum
https://linustechtips.com/topic/7003-vbnet-help/#findComment-102841
  • 3 weeks later...
To read in the text file:
Dim fileReader As StringfileReader = My.Computer.FileSystem.ReadAllText("C:\test.txt")MsgBox(fileReader)
To then write the text file out, add a save button and in the event handler put
My.Computer.FileSystem.WriteAllText("C:\test.txt", VariableContainingTheUsersText,True)
A better way of doing this
Firstly right at the top, before your form definition, Put the following line
Imports System.Environment
Like so:
As to where to write your text file, To maintain compatibility with Windows 8 I suggest writing to %appdata% like this (All of the below code goes in an event handler like OnClick
        Dim appData As String = GetFolderPath(SpecialFolder.ApplicationData)        Dim fileName As String = appData & "\test.txt"        My.Computer.FileSystem.WriteAllText(fileName, VariableContainingTheUsersText,True)
Current rig: AMD Piledriver fx-8320 OC'd to 4.9ghz on 1.45v vcore | Asus Sabertooth 990fx r2 board | Gigabyte 7950 W3x| 8GB Corsair XMS3 1333mhz | 240GB OCZ Agility 3 SSD
https://linustechtips.com/topic/7003-vbnet-help/#findComment-119839
