Wireless wifi adapter?
Go to solution Solved by Matias_Chambers,
Just now, ilysm matty [CASHING OUT] said:
https://uk.pcpartpicker.com/list/TFC6pb
thats probs the most i'd spend gg
Looks pretty good.
Holla, itsa me. Build - https://uk.pcpartpicker.com/list/h9rD7h
(I have BT Infinity)
So, I'm on the top floor of my house 2 floors away from the router and get 50mbps download and 10 mbps upload on my mac.
What wifi adapter should I use to get a good signal on my new build?
pokemon-exeggutors-new-form-is-egg-strem
https://linustechtips.com/topic/699416-wireless-wifi-adapter/
Just now, deXxterlab97 said:
Get a different power supply
A PCIE adapter type of wifi
I'm not using that power supply oops, that shouldn't be there.
https://www.amazon.co.uk/Aerocool-Integrator-500W-Power-Supply/dp/B00JKVHKSU/ref=sr_1_5?s=computers&ie=UTF8&qid=1480453497&sr=1-5&keywords=power+supply
https://linustechtips.com/topic/699416-wireless-wifi-adapter/#findComment-8945558
1 minute ago, ilysm matty [CASHING OUT] said:
that's even worse tbh
https://linustechtips.com/topic/699416-wireless-wifi-adapter/#findComment-8945562
https://uk.pcpartpicker.com/product/pxrcCJ/tp-link-wireless-network-card-archert9e
The signal from the router can only reach a certain distance so if you are too far away the wireless adapter wont matter.
Get this PSU instead: https://uk.pcpartpicker.com/product/zW4NnQ/xfx-power-supply-p1430sxxb9
Get this version of the 480 instead: https://uk.pcpartpicker.com/product/29wqqs/xfx-radeon-rx-480-8gb-rs-video-card-rx-480p8lfb6
https://linustechtips.com/topic/699416-wireless-wifi-adapter/#findComment-8945574
golly i cant spend that much on an wifi card kms
https://linustechtips.com/topic/699416-wireless-wifi-adapter/#findComment-8945590
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  (£249.51 @ BT Shop)
Motherboard: ASRock H81M-DGS R2.0 Micro ATX LGA1150 Motherboard  (£37.99 @ Amazon UK)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR3-1866 Memory  (£35.99 @ Novatech)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£41.99 @ Amazon UK)
Video Card: XFX Radeon RX 480 8GB RS Video Card  (£234.99 @ Amazon UK)
Case: BitFenix Neos White/Silver ATX Mid Tower Case  (£23.99 @ Overclockers.co.uk)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£49.99 @ Novatech)
Mouse: Logitech G402 Wired Optical Mouse  (£19.99 @ Amazon UK)
Total: £694.44
Generated by PCPartPicker 2016-11-29 21:13 GMT+0000
https://linustechtips.com/topic/699416-wireless-wifi-adapter/#findComment-8945601
