I have a corsair cx 750m and am trying to sleeve the cables. This is a semi modular psu. The problem that I am having is that I can not undo the semi modular end of the cable. I have the right tools. Please help me. I have already destroyed on of my pci-e cables by pulling the wire out of the pin.
Thank you so much
https://linustechtips.com/topic/695360-please-help-trouble-sleeving-cables/
Thank you so much
For semi-modular units they are a bit of work since it would be easiest to open up the PSU to do the work, but you can sleeve it without opening it by cutting off the orginal sleeving.
