Asus maximum hero viii, 6700k hardware.. now the problem is that when ever we set voltage on the CPU say 4.6ghz @1.35v it never actual stays at 1.35v and often hits over 1.4v and to get 1.35v it must be set to 1.3v. I relise it not really going to dmg and is pretty normal from what Iv seen but friend is worried about it and curious about if can stop this?
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
https://linustechtips.com/topic/694388-voltage-higher-than-set-when-overclocking/
1 minute ago, stationvsbox said:
it probably just rounds to 1.4
Rounds to 1.4? Can you explain what you mean please?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
5 minutes ago, Naeaes said:
OP, are you using AI Suite 3? If so, stop it. It doesn't work. OC manually from BIOS.
well if my math from elementary school is correct, decimals get rounded up if the number is at least 5. So 1.35 would be rounded up to 1.4
No not using Ai suite. Overclocking via bios.
And no i really dont think hwmonitor etc is going to round up a whole .5v unless you know the motherboard manualy does it which its most likly not "rounding" and is some other form of overvolting wizardry.
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Its the load line calibration on the board overshooting.  The best way to fix these things are to disable all power saving and speed step and run fixed voltage all the time. :)
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
It is but it doesn't quite apply here. :D You can't round out significant decimals. It's not the year ~2020 and a day isn't ~30 hours long and so on. The few hundredths of a Volt make an actual and crucial difference in CPU operation. You simply cannot ever round it to a single decimal.
The board is set to high performance, voltage is manual fixed mode and epu power savings speed step etc all disabled.
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
OK so it is just the LLC overshooting a little.  Not much you can do.  Also you have to remember this is software so it maybe be reading a bit off. I would just set it to the lowest voltage that works and go with that :)
Rig Specs:
Load line is set to auto. Is it safe to disable this or set it to 10 which I assume is the lowest? What will it effect apart from voltage if anything else. I have it set to highest (1) on my b150m and voltage never overshoots on there but this isn't my own hardware so wanting to be alil cautious.
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
I have LLC settings I can change if  its safe too.
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Yes change it to the various different settings and see what happens and what works best.
Rig Specs:
Changing this between 1/10 makes no difference. @1.35v 4.6ghz under aida64 test it hits 1.42v and around 90c this seem to hot for 1.35v and 360mm aio. And the Problem with running 1.3v is at idle it dips slightly .1ish v which may cause idle instability at 4.6ghz as under load 1.275v was unstable but 1.3v is  ;s any more suggestions? Faulty board/CPU maybe?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
This is super obvious,  but Lastest bios?
Rig Specs:
Not latest bios I'll find out exactly.
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Its running 1902 with the 2202 being latest with a CPU uCode update what ever that is. I guess that's the next thing to try will let you know how it goes anyway..
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
