I built my first PC and (I made a topic on this yesterday) it won't boot up completely. The power supply (CX600M) turns on, then turns off, then turns on again. This happens over and over. First, we thought the power supply was bad, so we got another one, but that still didn't fix the problem. The monitor isn't getting a signal when plugged up to the computer, and the LED on the power button turns off, then on, then off again, just like the power supply. And everything was plugged into a surge protector. And we checked the voltage and that was right as well. What's the problem? We check all the cables, reseated the RAM, and changed the power supply. What's the problem? Do I need a new motherboard? Because when we jump start the power supply without plugging it into the mobo, the fan stays on.
My build in fancy text: http://pcpartpicker.com/list/BWGdxY My current build: http://imgur.com/gallery/sOgMR3u
https://linustechtips.com/topic/693202-first-pc-not-working-whats-the-problem/
Check the header cables are connected to the motherboard correctly, try one stick of ram, remove the GPU and see if it boots
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
1 minute ago, Growlithe said:
Did you make sure you have the front panel headers wired correctly?
Did you try jumping the motherboard its self?
Yes, we have redone the front panel headers so many times. How do you jump a mobo?
We checked all the cables, and we haven't put the GPU in at all. I'll try the one stick of ram
Got a fan connected the cpu fan header?
Ryzen Ram Guide
Yeah, we made sure to do that. I think it's the motherboard.
