so i have a closed loop cooler as standard it has 1 connector on the cpu block for power and 1 on the fan but im not sure if i should plug the fan into the cpu fan connector or the cpu block cable?
Slowly but surely making myself comftable in a life i have built since childhood.
I like recieving replies, mention or quote to get my attention
https://linustechtips.com/topic/692879-need-help-with-a-losed-loop-cooler/
ok i plugged the pump into cpu1 and the included fan into cpu2 also you can simply clock on the water cooler in my spec list
